passlock help please
Old Mar 24, 2009 | 02:33 PM
blkblazer's Avatar
blkblazer is an unknown quantity at this point
Default passlock help please
I have a used steering column with key. If I have a new lock cylinder coded to my original ignition key put in the used column and install the used column in truck can I run a 30 minute passlock relearn or will it fail to start.
If I cannot do above, can I switch passlock sensor from original column to replacement column with the new lock cylinder coded to my original key or will it fail to start.
Do I need a gm computer to reprogram.
1999 S10 Blazer LS 2 door auto 4.3L auto 4x4
Thanks for assistance.
Old Mar 24, 2009 | 06:06 PM
Just do the relearn. Start with the short relearn. If you cannot get it to go with the short or long DIY relearn, then you may have to go to the dealer.
PASSLOCK - Reprogramming Auto Learn
You should be able to start it after leaving the key in the RUN position for 5 minutes though.
eknox327
25
Dec 13, 2018 11:33 PM
knight1292
Aug 14, 2008 09:30 AM
blkblazer
Jun 27, 2008 04:47 PM
phantom
Mar 18, 2008 02:10 PM
WolfPack
Nov 13, 2007 09:37 PM
