pinion seal/yoke
Old Aug 15, 2012 | 11:07 AM
Kknd310's Avatar
Kknd310 is on a distinguished road
Default pinion seal/yoke
So i just replaced my rear pinion seal on a 1998 4x4. Everything went relatively smooth. My question is before i pulled the seal out there was a an up and down play in the yoke. With the new seal there isn't, but i didn't have a torque spec on the nut that holds the yoke in. Is there supposed to be and play in the yoke? My instincts tell me no butttt you never know. Better safe then sorry.
Thanks
-Mike
Old Aug 16, 2012 | 06:46 PM
The nut in the center of the yoke obviously holds the yoke on but, it also adjusts the preload on the pinion bearing. If/when the nut is loosened or removed, the pinion shaft will move up and down. Before removing the yoke nut, you need to check the torque necessary to rotate the pinion with an inch pound torque wrench and record for reassembly. Then mark the pinion shaft and yoke with an awl. When reinstalling, tighten the nut until the lines match up, then check rotating torque with an inch pound torque wrench and adjust as necessary. If the torque is not correct, over time it will destroy the pinion bearing.
rodono
Mar 3, 2011 09:56 PM
blaze1002
Dec 6, 2008 03:00 AM
joey
Aug 5, 2008 08:40 PM
ahawks47
Aug 1, 2008 03:00 PM
mikepro
Sep 27, 2007 06:00 PM
