please check my thinking
Old Nov 10, 2011 | 04:05 PM
lloyddavid's Avatar
lloyddavid is an unknown quantity at this point
Default please check my thinking
'95 Jimmy, 2 door, auto 4x4, okay couple of weeks ago the truck acted like it ran out of gas and has not started since; checking fuel pressure today at the valve at the plenum I turn the key on, get the fuel pump noise and a whopping 20psi which drops to nothing as soon as the fuel pump stops. So, there are no leaks that I can find, that does not seem like enough pressure to start the truck so I am thinking **** poor fuel pump.
new in last 6 months: battery, TPS, MAPS, fuel pressure regulator, plenum gasket, cleaned EGR valve, coil, cap/rotor/wires/plugs.
Old Nov 10, 2011 | 04:18 PM
Mike7075's Avatar
Mike7075 is on a distinguished road
That's really low...should be around 60 psi. Hopefully someone can chime in with a range of normal pressures. Sounds like a weak fuel pump or a really clogged up fuel filter!
Old Nov 10, 2011 | 04:54 PM
Mike98Blazer's Avatar
Normal fuel pressure is 60-66 psi.
I think MINIMUM is something like 58.
Leakdown is 10 minutes shouldn't drop below 55 i believe.
Sounds like pump or FPR.....I'm betting on pump.
When replacing use DELPHI or ACDelco ONLY...if you don't you'll be replacing it again in short order.
Also, check the link in my sig ....there's a tech article in there to test the fuel system and make SURE it's your pump
Old Nov 10, 2011 | 05:00 PM
chris015's Avatar
^^^what he said to the T!
Delphi or ac delco only...sure buy a cheap pump. you'll be making another "car wont run" thread soon lol....
Old Nov 11, 2011 | 03:41 AM
lloyddavid's Avatar
Yes, that is why I am posting car won't run, cheap fuel pump about six months ago. The good news is the straps and bolts and nuts are new and it is really clean up in there now. If you have a favorite vendor for the pump and assembly feel free to let me know.
Old Nov 11, 2011 | 08:29 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
What about the injectors? If some are leaking wouldn't this cause the same problem?
Old Nov 11, 2011 | 01:01 PM
Rockauto.com is my "favorite vendor" If you google rockauto discount codes you can usually find a 5% off online coupon.
1994BlazerS10
Nov 29, 2009 07:22 AM
rogggg1020
Nov 11, 2008 08:05 AM
DavidBoone
Jun 21, 2006 06:41 PM
ivannj
Engine & Internal
Jan 20, 2006 10:52 PM
Dodge Guy
Jun 28, 2005 02:04 AM
