Plugs for Oil Cooler Holes in Radiator
Old Feb 4, 2017 | 02:49 PM
Scooter M'Gee's Avatar
Scooter M'Gee is on a distinguished road
Question Plugs for Oil Cooler Holes in Radiator
I will be eliminating the oil cooler on my winter beater as the lines are leaking. I have the piece to install the oil filter once the adapter is removed.
Does anyone have a source for plugs that fill the holes left in the radiator once the lines are removed?
Old Feb 4, 2017 | 03:39 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Just cut the aluminum lines, crimp them over and smooth them off. That will keep stuff from getting in there...
Old Feb 5, 2017 | 12:05 PM
While I appreciate the response I'm looking for a more OEM and pulled together finish.
Old Feb 5, 2017 | 12:57 PM
richphotos's Avatar
Its a winter beater, does the OEM pulled together finish really matter THAT much?
Old Feb 5, 2017 | 01:09 PM
I'm a stickler for details. So, yup.
Old Feb 5, 2017 | 01:52 PM
Not enough of a stickler for details to fix the lines properly?...
Old Feb 5, 2017 | 03:26 PM
Bwahahahaha......this thing has 194xxx miles on it. It's driven less than 3000 miles a year during the winter months. 28 mile round trip commute all surface roads and never sees more than 45mph. I could care less if it has an oil cooler.
Old Feb 5, 2017 | 03:46 PM
CWBDDSPC's Avatar
It will look oem finished from the top side if you do it right. You only see the top of the upper line anyway unless you start to remove the shroud ...
Old Feb 5, 2017 | 03:49 PM
So you're a stickler, but not a stickler... Gotcha.
Why care that there is anything in the ports? It's not like anything is going to leak out of them other than trace oil that might be left in there. Brake cleaner and a few blasts of air can flush that residual out and that would be that.
If it really keeps you up at night worrying about some insect making a home in there, go buy an assortment of nylon caps and see what fits. A direct fit, sealed plug for this application does not exist.
Old Aug 1, 2020 | 11:00 PM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
I know this is an old thread, but thought I'd add a little something for future reference.
A -8 AN ORB plug with o-ring screws right into and seals those holes after you remove the old fitting. They have the correct NPS - American National Standard Straight Pipe Thread in 3/4" x 16tpi. Same as the OEM bottom O-ring fitting has, but with the o-ring at the top under the hex head. Cost about $4.50 each in anodized aluminum and look very professional.
There are also 8 cent plastic red plugs made with that thread, but the only place I could find them the minimum order was a box of 200.
Squatcher
Apr 9, 2024 09:08 PM
Spencer Hedger
Mar 17, 2013 02:49 PM
tlbbrannon
Jul 14, 2011 01:11 PM
greenbean
May 22, 2009 07:41 AM
splat
Dec 17, 2006 09:47 PM
