Oil Cooler Question
Old Jul 11, 2011 | 02:30 PM
tlbbrannon's Avatar
tlbbrannon is on a distinguished road
Post Oil Cooler Question
I am in a bind i got a new radiator for my 4x4 blazer but it dont have oil cooling lines in it, I was told by a mechanic that the oil cooler was for towing and 4x4. i dont do either and need my truck now can i just bypass the oil cooling lines? my friend has a 96 also 2wd his does not have the oil cooler.
Old Jul 11, 2011 | 02:37 PM
You'll screw around more trying to bypass it than you will just getting the proper radiator for your application.
Old Jul 11, 2011 | 02:40 PM
tlbbrannon's Avatar
i can not just connect top and bottom lines together?
Old Jul 11, 2011 | 02:43 PM
Sure you can. It's your truck. I wouldn't recommend it, but that is completely up to you.
Are you doing this yourself or is there a mechanic that is responsible for ordering the wrong radiator and is now trying to talk you into bypassing factory equipment because of their mistake?
Old Jul 11, 2011 | 02:48 PM
tlbbrannon's Avatar
I am doing this i dont tow anything or use 4wd as i have only used it once in 5 years i have a family of 6 and we have no way to the store or anything right now can i do this then install a external oil cooler later?
Old Jul 12, 2011 | 03:25 AM
maddie's dad's Avatar
maddie's dad is on a distinguished road
If the original radiator had an oil cooler for the truck, I advise staying with the original set up. True, an oil cooler is strongly recommended for towing and off roading, but any automatic transmission can benefit from an oil cooler. If you insist on using the radiator without the cooler in it, then I think you should install an external oil cooler as soon as possible. Automatic transmissions generate a lot of heat even when they are not being driven hard. A buddy of mine specializes in transmission rebuilds and he says that the number one cause of auto transmission failure is due to overheating. He runs an aftermarket external oil cooler in conjunction with the factory radiator oil cooler on all of his cars and trucks.
Old Jul 12, 2011 | 11:17 AM
coolasice's Avatar
coolasice will become famous soon enough
it should have oil and transmission cooler lines on it...
Old Jul 12, 2011 | 07:23 PM
tlbbrannon's Avatar
Smile
Its fixed guys the new radiator had only oil cooling lines the old one busted on the oil side so i took off the tranny cooloer end cap and drilled holes in the new raidator and put the tranny cooler inside and put the end cap on. Its not as hard as its made out to be removing the end caps. just need a hammer a pair of vise grips a flathead screwdriver that will fit between the tabs and a bar clamp.
Old Jul 14, 2011 | 01:11 PM
Glad that it worked out for you tlbbannon. I must admit I've never tried removing and replacing the plastic end caps on a radiator.
sledge hammer
May 5, 2014 12:37 AM
fslobodecki@yahoo.com
Apr 15, 2011 03:29 PM
subarugt06
Mar 6, 2011 11:21 AM
shooter2499
Feb 4, 2008 09:23 PM
Jetfixer
Jul 11, 2006 05:02 AM
