poping noise when getting in truck
Old Mar 1, 2009 | 09:07 PM
Default RE: poping noise when getting in truck
After I installed new shocks, I had a similar problem. It ended up being the shock mounting bolts. The steel liner to the bushings on the shocks were not as wide as the original shocks. So the bolts needed to be tightened much tighter to pull the mounting tabs in against the sleeve in the new shocks. Drove me nuts.
Old Mar 2, 2009 | 10:01 PM
95LS's Avatar
95LS is an unknown quantity at this point
ill try that but how long after you put the new shocks in did it make the noise? like i said it had new shocks on the truck when i bought it right about a year ago.
Old Mar 2, 2009 | 10:26 PM
Cavalier z24's Avatar
Cavalier z24 is on a distinguished road
ORIGINAL: dBsound
But, I have a cousin that will change two for a 30 pack of PBR!
mmm Paps blue ribbon
Old Mar 3, 2009 | 07:33 PM
Made the noise right after I put on the shocks. I had a noise prior to the new shocks though. It just got a bit worse when I put the shocks on. Proceeded through the ball joints which needed to be changed. Then to the hood pin washers (TSB). And finally back to the front shocks.
Old Mar 4, 2009 | 07:15 PM
95LS's Avatar
ive never had to change cv shafts. the only ones i come across online is cardone/A1 i assume theres not a lot of diffrence between cv shafts so these should be good enough ?
Palomartony
Dec 17, 2013 01:47 PM
duckland23
Jul 22, 2012 02:03 AM
AlaskanK5
Jan 31, 2010 08:08 PM
96chevblazer
Nov 1, 2009 06:23 PM
jeremysbarlow
Oct 11, 2007 07:57 AM
