power loss
power loss
I have a problem with my 96 Blazer. Symptoms are: while driving sometimes engine skips and if I accelerate around 3000 rpm. Engine hesitates/power-loss. It feels like there is not enough fuel delivered to the engine or the fuel being cut off.
One more thing, all this happened after I replaced the fuel pump, for the first 45 minutes I drove the truck everything was ok, and then I notice the problem.
Could it be the fuel filter?
Thanks,
Paul
Thanks,
Paul
RE: power loss
I'd do a complete tune-up if not done lately...plugs, wires, rotor, cap, clean egr, clean maf, clean iac, etc...
RE: power loss
But the truck was running perfectly ok before the fuel pump change.
Paul
Paul
RE: power loss
Did you turn the key to the on position and off agian like 12 times after you changed the pump? Not start, but on. This primes the fuel system, fills up the fuel fitler, canister, and all lines again. If not, you wont have enough fuel at higher rpms.
If you did that, replace the fuel filter. Then do as above, and if that doesn't fix your problem. Post up, it might be your fuel pressure regualtor or leaky lines under the intake manifold.
RE: power loss
What are you running for an air filter?
RE: power loss
Just regular ACDelco air filter.
For some reason I think that the problem with my truck is fuel related, because like I said before everything was ok up until my fuel pump went and I had to install new one.
RE: power loss
Pretty much the only way to check for fuel related problems is with a fuel pressure tester/gauge. If you have one or have access to one, I can explain further.
bryanmine
05-19-2011 11:27 AM
kerander
01-18-2007 01:21 PM
the wood
10-29-2005 12:48 PM
