power loss with a/c on
Old Jul 8, 2007 | 09:58 AM
00blazer4x4's Avatar
00blazer4x4 is an unknown quantity at this point
Default power loss with a/c on
i have a 2000 blazer ls. when i turnto one of the3main a/c settings it struggles to get up to speed and seems to have little power, but is fine when the a/c is off. it also does it when i have the heat turned on one of those three settings. also the three setting i'm talking about are the a/c, max a/c, and having it on your face and legs. any ideas?
Old Jul 8, 2007 | 10:45 PM
FFJustin99Chevy's Avatar
FFJustin99Chevy is an unknown quantity at this point
Default RE: power loss with a/c on
The AC makes sense to an extent because it's another strain on the motor to run it. Obviously, the more belts you start running off of that motor, the less power that is actually going to make it to the wheels. However,I thoughtthat the engine heat was vented for your HEAT controls. So, that wouldn't exactly coincide as an understanding to your problem.
Could you describe how much the truck is hurting for power while you're running the a/c?
Old Jul 8, 2007 | 10:59 PM
EuroGoldLS's Avatar
EuroGoldLS is on a distinguished road
You'd expect power drain to a certain extent. If it is significant power drain it means that you may have a bad bearing on your compressor,or else the A/C systemis low on oil; thusincreasing friction. Do you hear any kind of roaring or squealing noise when A/C is engaged?
All three settings, (A/C, Max A/C, and Bi-lev) you described are A/C settings and the compressor should engage when switched to those settings, even if the thermostat is turned all the way to heat.
bryanmine
May 19, 2011 11:27 AM
kerander
Jan 18, 2007 01:21 PM
mdhokenson
Apr 19, 2006 07:21 PM
paul06
Jan 17, 2006 04:54 PM
the wood
Oct 29, 2005 12:48 PM
