power mirror fuse??
Old Nov 29, 2009 | 07:40 AM
noseback's Avatar
noseback is on a distinguished road
Default power mirror fuse??
i can't figure out which fuse is it that powers the power mirror option! i'm getting tired of them vibrating and pointing into thier own directions every time i hit a bump, i want to relpace the fuse so they work and hold thier positon. a picture of its location or which fusebox/fuse location/fuse type would be greatly appricated
car is 95 s10 blazer 2dr
Old Nov 29, 2009 | 07:48 AM
Sisk's Avatar
Check the fuse box under the hood. There should be one marked "mir/lks" if I'm not mistaken. That should be the one you're looking for.
How did you come up with the problem being in the fuse anyway? are you sure it's the fuse, or are you just starting there?
Old Nov 29, 2009 | 08:38 AM
noseback's Avatar
trying to repair the cheapest way first...if not then maybe wiring from switch to motor is bad...maybe something else will try to dig deeper once i find out if its not the fuse.
ChromeJerome
Apr 26, 2015 03:19 PM
Joann
Oct 14, 2013 10:33 AM
AustinBlazer
Jun 4, 2013 10:35 AM
bigslik20
Aug 9, 2011 11:32 AM
Sherwood
Oct 12, 2007 09:21 PM
