Power Steering pump
Old Oct 25, 2011 | 02:41 PM
Jesster's Avatar
Jesster is on a distinguished road
Default Power Steering pump
I have a 1996 Blazer 4wd 4dr with the 4.3L. I replaced the PS pump and air conditioner compressor 6 years ago. At the time, I pulled the AC compressor bracket and everything was reasonably easy to work with. Currently, I need to replace the PS pump and have taken off the pulley, 3 front bolts, 1 nut on block stud post (bottom) and a nut from a bracket on the rear of the pump. The pump is still secured.
It looks like there is one more bolt on the lower backside, but I wanted to verify that the bolt is there and also, check with anyone out there: Should I unbolt the AC compressor (leave hoses connected) and move it to the side to unbolt the bracket? It seems that removing the compressor and bracket would again make this much simpler; I can't remember having any trouble last time. My Chilton's says the bracket may have to be removed.
Old Oct 25, 2011 | 03:16 PM
GryphonBlaze's Avatar
GryphonBlaze is on a distinguished road
Hey, I have access to Alldata Online and here is what it says to do.
  1. Disconnect pressure and return hoses from power steering pump or steering gear housing, then secure ends in raised position to prevent oil drainage. Cap all open lines and fittings.
  2. Remove power steering pump belt, then power steering pump attaching bolts.
  3. Remove power steering pump assembly.
  4. Reverse procedure to install.
    Hope this helps!!!
    Here's a pic of the diagram as well.
    http://i896.photobucket.com/albums/a...ersteering.gif
Old Oct 25, 2011 | 04:32 PM
trucktom's Avatar
trucktom is on a distinguished road
yeah pull the backet takes 10 minutes and is SOOOO much nicer to do
1991whiteoutblazer
Jan 8, 2009 08:17 PM
Hogwash
Jan 27, 2008 08:02 PM
irata
Jul 7, 2007 03:36 PM
strykerthat
Jul 5, 2007 03:49 AM
Hanr3
Engine & Internal
Apr 3, 2007 02:38 AM
