power window issues
Old May 5, 2009 | 10:36 PM
65longroof's Avatar
65longroof is an unknown quantity at this point
Default power window issues
Ok I had my dash out over the weekend put it back in and all seemed fine. Well today 3 of the 4 windows stopped working with there individual switches but they DO work from the main switch panel on the drivers door.
Any ideas?
Thanks guys
Old May 6, 2009 | 06:45 AM
I can't remember if the 95 has the window lock button like the 98+ does... If so, check that.
Old May 6, 2009 | 01:24 PM
65longroof's Avatar
It does and I checked....unless it went bad. I do have one plug under the dash I am not sure what it is for. It is in a "pocket" next to the one that all of the head light wiring goes through.
Old May 6, 2009 | 03:30 PM
Pop up the master window switch on the driver door and see if any connections are loose or corroded. We had that happen on my parents old Cadillac and it was a loose connection.
Old May 6, 2009 | 03:56 PM
65longroof's Avatar
I rocked it back and forth a bunch of times and now it seems to be working.......just a sticky or corrodid switch......I'll check into it a little deaper tomorrow.
Thanks
Old May 6, 2009 | 04:37 PM
bandidolenny's Avatar
Yea, those switches are kinda in a susceptible place to get wet if you ever have to roll down your window down in the rain. I believe this is kinda common. You probably will be replacing your switch sooner or later but I would try to "clean" it out with electrical contact cleaner first.
e602
91
Mar 8, 2015 04:53 PM
K5Blazer87
May 28, 2014 01:35 PM
bigslik20
Aug 9, 2011 11:32 AM
cruukedeye
Jun 4, 2011 06:49 PM
hillbillyinOhio
Jul 12, 2006 04:18 AM
