power windows not working
I just got a 98 blazer 4 door a couple days ago and on my test drive everything worked as it should (this was 4 days ago) now when I went to go use my window switch on my passenger side they didnt work but my power windows work fine on my driver side panel. when I try to use them on any other it just wont go, I've tried with both the window locked switch on and off and still nothing. also when I hit the lock switch on the passenger front door my dome light flickers. does anyone know what could be causing this?
I just noticed how I wrote my first post and I wanted to clarify it. My whole drivers side door window panel works fine for all of my windows in my truck but when I go to use the door panel on any other door it does not work even turning the window lock switch doesnt work. I checked all my fuses on the side of the dash and they were all fine. and I didnt see and fuse for them under my hood (I could be wrong I checked very quickly)
Okay I will try that tonight when I get out of work also this might sound dumb but how do I get the harnesses out of the door window panel I tried using a flat head to unclipthe clip but it doesn't seem to want to come out? I am trying to replace mine since my top clip snapped an it won't stay in place.
actually you don't have to pull the dr pnl. i just put mine back together, grab the the frt of swt and pull back and up sharply. it should pop out, you mite need a screwdr if its never been apart. the conn are a #@%$%$ to get apart. 1/4" screwdr slid down in and a lot of wiggleing to get'm out , check for loose conn first, my swt was fryed ,prob due to water through the open window, not made like used to be.
