Problem air temp overhead
Old Oct 24, 2009 | 02:51 PM
ebornand's Avatar
ebornand is an unknown quantity at this point
Default Problem air temp overhead
Dear, I have problems with the overhead temperature sensor, the clock will hit the marker at 35°C, that is?
Thanks.
Old Oct 24, 2009 | 03:36 PM
rriddle3's Avatar
Huh?
Old Oct 26, 2009 | 07:08 AM
ebornand's Avatar
I mean I have problems with the temperature sensor of the overhead, the temperature is not the real mark on the environment.
Old Oct 26, 2009 | 08:43 AM
rriddle3's Avatar
Okay, how much difference is there between the actual outside temperature and the reading on the overhead console?
Old Oct 26, 2009 | 09:04 AM
ebornand's Avatar
The temperature that marks the console between 81ºF to 98ºF, the outside temperature is 58 º F.
Thanks.
Old Oct 26, 2009 | 10:12 AM
rriddle3's Avatar
The sensor unit probably needs to be replaced. It is located in front of the radiator, behind the grill.
Old Jan 23, 2010 | 01:07 PM
ebornand's Avatar
I got another temperature sensor, but continued with the offset of temperature, but the next day marked the actual temperature sensor of the environment, but then failed again. I think the fault is not the sensor, should be another element.
Old Jan 24, 2010 | 09:18 AM
portcqb's Avatar
portcqb is an unknown quantity at this point
If the other sensor is actually good, and the wire running between it an the overhead console. It may be the overhead console going bad.
zakm0n
Jan 9, 2011 07:31 PM
streblo
Nov 25, 2009 10:56 PM
highlife756
Nov 18, 2009 06:58 AM
walsh_554
Mar 20, 2008 04:01 PM
DaShark
May 16, 2006 06:13 PM
