Problem with driver's side window control buttons
Old Nov 5, 2010 | 06:58 AM
oasysco's Avatar
oasysco is on a distinguished road
Default Problem with driver's side window control buttons
1996 Blazer, 4WD, 4-door.
The control panel in the driver's side arm rest that runs all the windows has come loose from whatever secured it. The whole unit is pushed down into the armrest. I can run the windows, but it's a bit of a pain to have to move the control unit back a little or to the side so the keys don't get stuck.
I can get the unit back up, but how do I secure it so it doesn't slip back down under the holes in the armrest?
Do i need to take the door panel off to address this issue or can I do it less invasively?
Thanks,
Greg
Old Nov 5, 2010 | 03:56 PM
franklin's Avatar
franklin is on a distinguished road
The bezel/trim that goes around the window switch could be removed with out removing the door panel. It should clip in one end and hook into the other end. a trim stick tool or a screw driver should remove this trim with out any problems. The tabs that hold the switch to this trim might be broken. but you should see that when you remove this trim.
Old Nov 7, 2010 | 04:12 PM
oasysco's Avatar
Unfortunately, there is no bezel around the switches. The armrest is one piece, including the cutouts in the armrest for the window buttons.
Old Dec 14, 2010 | 10:23 AM
1st time blazer owner's Avatar
1st time blazer owner is on a distinguished road
It shouldn't be, on my '95, the armrest is 2 peices, one is the actual armrest, the other is the switches, the '97's are that way aswell. Unless you have a rare, "gotta pop the entire door panel off" it should be standard
mamawolf70
Apr 10, 2020 10:44 AM
benjamin tate
Jan 17, 2012 07:19 PM
rlarge2000
Mar 14, 2009 12:45 PM
MindzEyeWRX02
Mar 20, 2008 06:11 AM
hillbillyinOhio
Jul 12, 2006 04:18 AM
