problem with my cruse controll
Old Jun 28, 2015 | 08:39 AM
pmanwarren2015's Avatar
pmanwarren2015 is on a distinguished road
Default problem with my cruse controll
ok i when to work yesterday and the cruse control stuck on full rev on in my 2000 blazer and it didn't shut off after i stepped on my break can any buddy tell my why or a good place to test thanks
Old Jun 28, 2015 | 08:45 AM
I would suspect a problem with either the main throttle cable or the cruise cable. You can test their return springs by opening the throttle wide open and slowly closing it while seeing if one of them gets slack in the cable. If there is slack, it isn't returning.
Old Jun 28, 2015 | 03:32 PM
rxjimmy's Avatar
rxjimmy is on a distinguished road
Were you running on "cruise" when you pressed the brake and the engine rev'd?
Old Jun 29, 2015 | 07:41 AM
thanks a lot i will test it today
yes i was going about 55 and then i tried to push the break and it didn't shut off the cruse so when i pushed in on my break my truck was still in gear and it wasn't stopping i shut off the blazer and then when i got to work i put in park and thats when it revd so i floored the gas and thats when it stopped that was a freaky ride say the least
Old Jul 8, 2015 | 01:34 AM
dragoon1101's Avatar
dragoon1101 is on a distinguished road
i would replace you break switch its what tells the cruse to shut off when you hit the brake it is attached to the side of the brake peddle with a clip and a plug
Sulley
Feb 4, 2012 11:06 AM
BBQ Bandit
May 24, 2011 01:09 PM
anthonyd1511
Feb 7, 2011 11:58 AM
thebigjimmy
Jan 23, 2010 03:07 PM
illtww
Jul 23, 2007 09:41 AM
