Problems with Climate Control Zones
Old Nov 29, 2019 | 05:31 PM
Jukebox79's Avatar
Jukebox79 is on a distinguished road
Default Problems with Climate Control Zones
I have a 2000 Blazer 2dr 4x4
ac works, heat works but it seems to be stuck in the middle zone( main vents). It will not change to floor or defrost, either on heat or a/c. I do hear a small vacuum leak under the dash. Was looking for some advice before i start tearing dash apart. Any help will be greatly appreciated........
Old Nov 30, 2019 | 08:28 PM
GeorgeLG's Avatar
If Christine 208 does not answer, PM her and shell get you on the right track
George
Old Dec 2, 2019 | 02:46 AM
Scott Reynolds's Avatar
Scott Reynolds is on a distinguished road
im having the same problem there to also with transmission shift solid b two transmissions same problem
Old Dec 4, 2019 | 10:07 PM
These vacuum systems can be annoying.
The first thing to check is if the vacium hoses in the engine compartment are in good shape. I have a link below for checking and replacing those hoses.
As for the under-dash hoses, those are plastic and more durable and if you are hearing what sounds like air leaking, I would guess that the hoses likely became disconnected from the diaphragm actuators. Some of these can be accessed without taking the dash apart.
If the diagrams for the HVAC vacuum hoses are not in my thread below, reply back and I'll try to find them.
Good Luck
ryankenn
Apr 1, 2018 11:59 PM
KDB
Aug 15, 2015 10:32 AM
Izzy207
Apr 17, 2014 11:05 AM
zdorsch
Oct 3, 2012 05:56 PM
Clay_Assassin
Mar 18, 2008 09:36 AM
