problems in the rain
Old Dec 9, 2012 | 04:49 PM
Eddie Clark's Avatar
Eddie Clark is on a distinguished road
Default problems in the rain
i have a 2000 blazer that when i drive it in the rain it losses all power, gauges and the abs light comes on and then goes off after you drive it a bit any info would be greatly appreciated thanks
sorry for double post. can't figure out how to delete it.
Old Dec 9, 2012 | 05:20 PM
spittybays
Guest
Posts: n/a
Never any problems with no rain? Without the rain in the equation I'd say simple. Ignition switch. No codes just rain huh.
Old Dec 9, 2012 | 05:22 PM
its not the ignition and the only code it throws is for the evap system
Old Dec 9, 2012 | 07:33 PM
OhioLefty's Avatar
OhioLefty is on a distinguished road
I had a vehicle that did this and it ended up being a cracked distributor. Only ran bad when it rained. Just throwing something out there to look at.
Good luck...
Old Dec 9, 2012 | 07:40 PM
50lb_cat's Avatar
+1 on the distributor. Running badly in damp conditions is a classic sign of a bad dizzy.
Old Dec 9, 2012 | 10:50 PM
WalkGood's Avatar
WalkGood is on a distinguished road
I occasionally get a stumbling in damp wet weather , when first driving. Stumbles and reluctantly shifts from 1st to 2nd. Like it just doesn't want to shift into 2nd. After driving a few minutes it goes away. Only happens in the 1st to 2nd shift - never in 2nd to 3rd, 3rd to 4th.
Old Dec 10, 2012 | 03:45 PM
grizzstang's Avatar
grizzstang is on a distinguished road
Mine used to surge in the rain. I replaced the cap, rotor and put dielectric grease on the all the plug boots off the cap. Problem gone. Unfortunatley the distributor sits right below the seam between the hood and the cowl so water drips on it. While you have the dielectric grease out do all the boots off the plugs too.
Old Dec 10, 2012 | 04:07 PM
thanks i will sure replace the distributor and grease up everything and i hope that fixes the problem
bjsx8f
Mar 14, 2016 04:33 PM
shotnva777
25
Sep 27, 2011 07:04 PM
maddzz
Mar 31, 2010 08:43 PM
PawNtheSandman
Engine & Internal
23
Aug 27, 2006 11:22 PM
blueice01
Jul 3, 2005 08:50 AM
