Pull One Fuse
Old Sep 28, 2011 | 03:09 PM
chris015's Avatar
Originally Posted by swartlkk
If you really must do such a thing, I would pull the CRANK fuse in the underhood fuse/relay center. Doing so will disable the starter. If you wanted to do this through a hidden switch, then you would need to get at the yellow wire on the ignition switch harness under the steering column.
Is the yellow wire the same on a 1st gen? Id like to install a switch just for the hell of it. I never knew what wire to tap into.
I guess yellow wire to 1 side of the switch,then yellow wire to the other side of the switch to the original?? Im basically just creating a bridge right? I suck at wiring -.-
Old Sep 28, 2011 | 03:14 PM
xgiovannix12's Avatar
I think so chris
you bridge it with the switch
Yellow wire---------Switch------------ Yellow wire
chris015's Avatar
Question is now,is where is a sneaky place to put it?
Old Sep 28, 2011 | 03:20 PM
Mike98Blazer's Avatar
Under the dash by your knees? Like up by the steering column hidden by the plastic "beauty" piece....dunno what it's actually called. the lower dash panel? yeah above that. gotta reach for it but i dont think a "dumb kid" would even think to look there.
Old Sep 28, 2011 | 03:26 PM
It's a purple wire on your truck provided it has an automatic (yellow if it has a manual trans). It runs straight from the ignition switch to the starter solenoid. The manual trans has this wire go through the clutch switch so you can grab it there. You can put the switch anywhere on the circuit really, but the closer to the starter the more secure it is given how easy it is to bypass the ignition key lock & start the older trucks. At least with the newer vehicles you have the passlock system to stop it from running for long if a novice tries to hot-wire your vehicle.
Any modification of the wiring adds another failure point in the system so I really don't recommend doing this.
Old Sep 28, 2011 | 03:35 PM
AJBert's Avatar
I still stand by my statement of correcting your son rather than altering your vehicle.
Old Sep 28, 2011 | 04:30 PM
I agree: It's like fixing any problem, don't try to fix the symptom, fix the root cause.
Old Sep 30, 2011 | 05:24 PM
kristoph30's Avatar
kristoph30 is on a distinguished road
I agree with correcting the behavior rather than modify the truck. Im curious what else he is doing beside stealing the blazer!
AustinBlazer
Jun 4, 2013 10:35 AM
Blazers.B.Kewl
Apr 22, 2013 10:06 AM
KevT
Sep 8, 2012 02:05 PM
Heffty
Jul 14, 2012 10:16 PM
burning_soul07
Feb 7, 2011 08:54 PM
