Q about replacing O2 sensor/air filter
Old Nov 11, 2010 | 02:29 PM
BugOut's Avatar
BugOut is on a distinguished road
Default Q about replacing O2 sensor/air filter
I've got a 2004 V6 Blazer and got the trouble code P0155, problem with the O2 sensor, bank 2 sensor 1. I went under there to check it out and it seems the connector is attached to the frame of the truck by a plastic "screw" type thing..one of those things that has the flanges that go in one way and you can't (easily) pull it out. I'm just wondering if I should yank it out or is there an easier way, and would a new O2 sensor come with one if I bust it?
Another question is about replacing the air filter...the radiator hose seems to be in the way of me pulling the air filter cover up and out of the way...any way around this aside from disconnecting the hose?
Thanks for any info..
Old Nov 11, 2010 | 02:39 PM
rriddle3's Avatar
Originally Posted by BugOut
...Another question is about replacing the air filter...the radiator hose seems to be in the way of me pulling the air filter cover up and out of the way...any way around this aside from disconnecting the hose?
Just push the hose far enough to the side to lift the cover. It takes a bit of a push.
Old Nov 11, 2010 | 05:51 PM
BugOut's Avatar
Thanks, I'll give that a try.
And is there only one O2 sensor on the passengers side? I want to be sure I'm going to remove/replace the correct one.
Old Nov 12, 2010 | 09:04 PM
BugOut's Avatar
Default Location of sensor
I've got the code 0155, where is the bank 2 sensor 1 sensor located?
Thanks!
Old Nov 13, 2010 | 05:04 AM
B2S1 is the upstream sensor on the passenger side. Upstream sensors are closest to the exhaust manifold. In your case, it will be the only one on the passenger side between the exhaust manifold and the catalytic converter.
Old Nov 13, 2010 | 09:55 AM
BugOut's Avatar
Great, that's the one I thought it was (the one just before the muffler). I was under there yesterday and saw another sensor just before the catalytic converter, so I got a little confused. The one near the muffler is easier to get to, so that's good.
BTW, what is the designation of that sensor just before the cat? Bank 2 sensor 2?
And any reccomendation on if I should pop the connector off the frame?
RolloT
Oct 9, 2014 04:46 PM
radiorara
Jun 21, 2011 07:39 AM
dimmuborgir6nik6
Oct 2, 2008 06:51 AM
riverjamie
Sep 24, 2007 08:21 PM
2001blazer
Feb 23, 2006 12:55 AM
