Question about 20w50 motor oil
Old May 24, 2015 | 12:23 PM
youngsm1980's Avatar
youngsm1980 is on a distinguished road
Default Question about 20w50 motor oil
Hi, I read some advice on another thread about using synthetic 20W50 oil in a high mileage motor that had developed a knock. My 1998 had a leaking intake gasket which I fixed but it has since started knocking. I did change the oil several times right after the repair to get as much water out as possible. (I replaced the gasket a few weeks ago and it seemed fine until yesterday when it started knocked pretty bad.)
I believe Mobil 1 20W50 synthetic was the recommended oil. The only oil I have been able to find like that is designed for motorcycles. Is this the oil that was being recommended? The blazer is very clean and I bought it recently so I am really hoping to get some more miles out of it. Thanks
Old May 24, 2015 | 05:03 PM
clicheche's Avatar
clicheche is on a distinguished road
tough call. try running 10w40 first maybe. i used that in my mazda b2200 and the ticking basically quit entirely.
Old May 24, 2015 | 08:39 PM
Your 98 was designed to use 5W30 oil. Using higher viscosity oil will increase oil pressure, which might quiet it down temporarily, but at the same time, oil volume will decrease and cause more damage. If the engine knocks using 5W30, the damage is done.
Old May 24, 2015 | 08:51 PM
Yeah, I figured as much but I am hoping to keep it going for my girlfriend until I get home to deal with it. (I am working out of town for the next month or so) Can the pan be dropped without removing the engine to change the crank and bearings or would it be easier to just yank the motor and have it rebuilt? Thanks for your input.
Old May 24, 2015 | 09:00 PM
Best to pull it out, check it all out, and do it right.
Old May 27, 2015 | 06:06 AM
Tajohns34's Avatar
If it is knocking it is best to pull it and redo the whole thing. Even if you have a new crank there could still be metal shavings and oil/water mixture throughout the engine. Or you can do what I did and get a junk yard motor with a 6 month warranty.
Old Dec 6, 2023 | 09:02 AM
catflannery78's Avatar
catflannery78 is on a distinguished road
no mobile one no longer makes a synthetic 20 W50 for high mileage vehicles. Iran, the castrol gtx, synthetic 20 W 50 in mine.
Old Dec 9, 2023 | 05:31 PM
LesMyer's Avatar
just don't use 20w50 in anything including race cars - it's obsolete.
LesMyer
38
Jan 9, 2020 11:45 AM
TFisher
Dec 15, 2009 02:27 PM
todaresqSL2
Nov 10, 2008 01:47 PM
rob1621
Feb 29, 2008 08:15 PM
quontush
May 1, 2006 12:50 PM
