Question about spider assembly
Old Aug 13, 2009 | 10:36 PM
midnightbluS10's Avatar
midnightbluS10 can only hope to improve
Default Question about spider assembly
I replaced the spider ***'y in my Blazer today. But, I ran into a small problem with one of the "holes" that the fuel lines connect to. It was missing the black plastic guide above the o-ring. While trying to remove the guide from the old spider ***'y, it split down one side. Being that it's only a guide to keep the fuel line positioned in the center, would it be ok to still use it? Apparently, you can't get them from the dealership. TIA!
Old Aug 14, 2009 | 09:52 AM
so I'm ready to set this **** on fire and watch it burn to the ground. The fuel lines are killing me. First, I couldn't get them attached to the spider assembly, so I broke them loose at the firewall. Now I can't get them connected at the firewall. WTF!?!?!?!?!?!?!?!?!? Anyone got any pointers to make this go a little smoother? I've already thrown a ratchet in the woods this morning. Not looking forward to going back out there. Thanks....
Old Aug 14, 2009 | 11:22 AM
Well I think I just toasted the bearings.....friggin great. I didn't change the oil before I started it back up and there was a harsh nocking sound. I shut it down immediately and drained the oil. Fuuuuuuuuuuuuuuuugggggggggggggggggkkkkkkkkkkkkkk
Old Aug 19, 2009 | 09:51 PM
sidewheeler's Avatar
sidewheeler is an unknown quantity at this point
Sounds to me like you dropped some smitnik down one of the intake holes when you had the top of the intake off. pull the plugs and see which one is nasty that will be the one. then it's time to pull the head and find a replacement. Parts is Parts. All it is is time. If your wrenching your riding. If your setting with your finger up your nose your walking. Get wrenching
eaglerex
Apr 24, 2010 04:18 PM
ddbigshoots
Apr 21, 2010 09:26 PM
bigdaddykane93
43
Jan 21, 2010 12:12 PM
JeffUSMC
Jan 16, 2010 12:53 PM
gw2009
Jan 12, 2009 05:04 PM
