quit running again
Old Dec 23, 2006 | 07:31 PM
97blz4x4's Avatar
97blz4x4 is an unknown quantity at this point
Default quit running again
hey yall,i have a 97 s10 blazer 4x4,it started missing on me the otheday and i asked you guys for help and come to find out it was the dis. cap.well ran good for to days then it just stopped in the middle of the road.dont know what happended.i got it hame and checked everything.getting good fire but wont start,not even with a gas rag.wont do nothing but turn over.i checked to timing all the way to fuel and vac lines.if yall have any idea let me know....
thanks brandon
Old Dec 23, 2006 | 08:54 PM
swdockter's Avatar
swdockter is an unknown quantity at this point
Default RE: quit running again
Having a hard time deciphering your question and information you provided.
Is is possible the distributor itself is bad? Maybe the trigger is shot. I'm sure someone will be able to help you out.
Did you check all the fuses and all the basic stuff like;water in the cap itself;wires are seated on the s-plug, coil and the cap etc....
Old Dec 24, 2006 | 03:24 AM
DINO55's Avatar
DINO55 is an unknown quantity at this point
Brandon,
When you turn the key to the on position, do you hear the fuel pump whine for two seconds?
Do the (idiot) lights in the dash cluster light up when the key is in the on position?
If you answered no to any of these questions, you most likley have a BAD IGNITION WIRING HARNESS..
Good luck and post back here with your findings........
Old Dec 24, 2006 | 03:50 AM
Chevy Lover's Avatar
Sorry, I also have some difficulty understanding. What do you mean by a "gas rag" and checked timing all the way to fuel and vacuum lines?
You say you get spark to the plugs? If you have spark, then you may have a fuel problem. As DINO55 said, do you hear the fuel pump run for 2 seconds when you turn the ignition to the "on" position?
Do you have a fuel pressure guage? You should have a minimum of 50psi fuel pressure to start the engine.
Old Dec 24, 2006 | 05:11 AM
MNHawk's Avatar
MNHawk is an unknown quantity at this point
If it has sat for more then a few hours, try again and see if it fires up, If it does try keeping the tank over 1/4. If it runs below 1/4 then the fuel pump over heats and stops working. And no one seems to know what you mean by GAS RAG. Not sure if its an Iowa term or what, but try to use more logic when you post. Might help in trouble shooting the issues with your ride.
dom d
Oct 14, 2014 05:32 PM
rlreusch
Nov 27, 2013 06:40 PM
HoustonOKIE
May 31, 2011 09:52 PM
rolrod21
Apr 3, 2011 03:01 PM
KRUSHER
Jan 2, 2010 07:25 PM
