Raising front end
Old Apr 28, 2008 | 05:04 PM
Brocktward's Avatar
Brocktward is an unknown quantity at this point
Default Raising front end
I installed an extra leaf spring to each side of the rear of my 95 due to the heavy cargo I carry, It raised the rear about 2 inches with it loaded, is it possible to raise the front end with the torsions bars, I only want to go about 1 inch in front?
Old Apr 28, 2008 | 05:15 PM
rriddle3's Avatar
Default RE: Raising front end
Yes, the TB's can do that. Raising it an inch should not put you into the danger zone on component wear, but I don't think going over that would be a good idea.
Old Apr 29, 2008 | 06:54 PM
Brocktward's Avatar
Thanks, I just replaced the front end so I think it would be a good time to do it.
Old May 1, 2008 | 10:05 PM
Brocktward's Avatar
I raised it 1 1/2" to sit even with the rear, it handles good and sits just a little higher than stock, I used "add a leaf" in the rear for $65 bucks and installed it in about an hour in the drivewaywith two small jacks, 1 on the frame and 1 on the dif., it isway better hauling a load now! Thanks!
Old Aug 16, 2009 | 12:06 AM
bigdaddykane93's Avatar
bigdaddykane93 is on a distinguished road
how exactly do you go about raising your front end torsion bars? i have a 1995 S10 4x4 and i would like to raise the front about 1 " but i do not know how to do it. can you explain?
thanks so much for any help
Old Aug 16, 2009 | 12:35 AM
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
check out the DIY section there is a How-To with pics included.
gtmccormick
Apr 24, 2015 07:29 AM
BLAZER97LS
Apr 16, 2012 02:56 PM
RWRIGHT
Feb 25, 2009 06:17 PM
Smoked
Tires and Wheels
May 7, 2008 10:40 PM
97blz4x4
Nov 12, 2006 02:25 PM
