Random stalls and no starts
Old Jun 10, 2019 | 02:03 PM
  #21
Mike.308's Avatar
Originally Posted by FUN-V
Oh, I've got the fancy scanners and scopes and jazz, this was showing nothing.
On the bright side, the new pigtails seemed to do the trick, the pins were loose in the connectors and one was corroded.
Some time ago I'd have a same story to tell. No code for my C16NZ engine and the engine doesn't start at all. Pretty useless. Finally I found the connection rotten at the cam shaft sensor. The ECM didn't had the feedback signal saying the engine cranks, so was giving no spark.
I'm not saying which attitude is best here. I say best if You can combine them both!
Old Jun 10, 2019 | 04:26 PM
  #22
GeorgeLG's Avatar
inspection of wires, connectors and hoses is a part of proper diagnosis for sure. My last misfire on the blazer was a loose spark plug wire. Didn't need a scanner for that. Also intuition about likely causes from experience or some reading plays a big part. I saw a misfire on cylinder 3 of the Toyota and why did I swap the coil packs first - because some research showed the fuel injectors don't fail often, the plugs were new and the coils are known to fail so I started there.
George
Old Jun 10, 2019 | 04:34 PM
  #23
Mike.308's Avatar
Originally Posted by GeorgeLG
inspection of wires, connectors and hoses is a part of proper diagnosis for sure. My last misfire on the blazer was a loose spark plug wire. Didn't need a scanner for that. Also experience about likely causes from experience or some reading plays a big part. I saw a misfire on cylinder 3 of the Toyota and why did I swap the coil packs first - because some research showed the fuel injectors don't fail often, the plugs were new and the coils are known to fail so I started there.
George
You're such a humble person, George. I know exactly what You mean. I've edited the quotation for accuracy.
Old Jun 10, 2019 | 04:40 PM
  #24
GeorgeLG's Avatar
I’m still working on humble, it may be a while yet. LOL.
George
David Nowakowski
Mar 29, 2019 04:03 PM
Philip Mildren
Apr 30, 2017 04:53 PM
metfanpt
Sep 26, 2009 12:40 PM
uwaidye
May 7, 2008 08:12 PM
millertimee
Mar 24, 2008 01:32 PM
