randomly stalls
Old Jul 25, 2010 | 11:12 AM
chizgod's Avatar
chizgod is an unknown quantity at this point
Default randomly stalls
i have a 2000 4x4 blazer it has stalled about 3 times in the last 4 months it does not over heat just stops running will crank but will not start ,but let it sit about 1 hour it will start and run fine it seems like somthings heating up and then stalls,and when it cools will start again changed wires plugs and cap and happend again. any sugestions?
Old Jul 25, 2010 | 12:31 PM
You can remove the ICM (ignition control module) and the coil and have them tested. Both, if overheated, can cause problems with starting.
When it isn't starting, does your 'security' light stay illuminated no the dash? If so, the problem could be with the ignition switch.
Old Jul 28, 2010 | 09:06 PM
chizgod's Avatar
i didnt notice if security light was on but in the past the icm fuse blew 3 or 4 times
Talusgirl
Apr 21, 2011 06:05 PM
pmezo
28
Nov 6, 2010 04:30 PM
Pollo
Aug 7, 2010 08:44 PM
cardsNblazer
Aug 11, 2008 08:26 AM
Sarahsmith854
Apr 17, 2008 08:47 PM
