rattle in front end on rough roads
My 2003 Blazer LS has a rattle that seems to be coming from behind the dash near the blower motor maybe. Had 2 different mechanics look at it as well as myself pulling everything apart, but just can't seem to find what is causing it. Doesn't seem to be anything important, so just turn up the music and wait for whatever it is to fail
It has been there for almost 2 years now.
That is what mine was doing but i found the rattle the hood hinges get wore and loose allows the hood to shake and rattle.
Easy fix i just stuffed a rag under each hing with hood open so when you close it up it will put tension on the hings. Presto rattle went away .
I have fixed every rattle in it silicone works great in the spots like plastic molding that may be rattling remove molding put a few dabs here n there reinstall fixed.
Seems that is what it was, the hood bolts/mounting bracket they go through are worn out. Had a piece of foam stuffed under there the past two days, as walleye recommended, and no more noise from that area! With the foam in there you can see how the passenger side is out of alignment and off. Going to replace them today or tomorow, thanks for the sugestions and help
thats my problem, and yes goes away when braking. its been months and i think ive finally figured it out. spent HOURS underneath testing everything. so your saying it wont harm rotors or wheel bearings?
