rattle noise when on gas
Old Aug 16, 2010 | 10:57 PM
Originally Posted by 4x4blazerguy
Thanks for your post. Your the first one I have heard that explained my engine rattle problem for the last 60,000 miles+. I emailed you wanting any other info you have about this issue. Where is the balance shaft located?
Thanks a bunch for your post.
If you need more information about this, have a look at the link in the quote below from way back in 2007 :
Originally Posted by swartlkk
If it is always from around 1800-2200RPM consistently, it is possible that this is resulting from torsional vibration in the balance shaft that is triggering the knock sensor, retarding timing and hindering performance.
This is documented in TSB 03-06-01-024.
Old Aug 17, 2010 | 11:36 AM
samuknow's Avatar
samuknow is an unknown quantity at this point
Follow up here as Kyle posted. there is also a ton of info on the web.
meatbag
Sep 24, 2012 10:26 PM
kickme005
May 24, 2010 07:21 AM
mikol23
29
May 13, 2010 02:49 PM
toaks
Jul 24, 2008 04:58 PM
762mm
Jun 16, 2008 07:03 PM
