Rattling right front brake caliper
Old Oct 23, 2013 | 08:01 AM
MJKH84's Avatar
MJKH84 is on a distinguished road
Default Rattling right front brake caliper
My right front brake caliper on my 1996 S10 Blazer has been rattling for some time. The brakes work fine, but the caliper is pretty loose on the brackets. The pins are tightened, yet the caliper still rattles annoyingly when I hit bumps or pot holes. Were there some kind of rubber bushings inside the pin holes that have perhaps worn away? What am I missing from the caliper that is allowing it to rattle so badly?
Old Oct 23, 2013 | 11:48 AM
richphotos's Avatar
Go to the parts store and tell them you need a pin and bushing kit for your front caliper. That will quiet it right up.
and you are right, there are rubber bushings that fit in a grove on the caliper, and then over that goes a metal sleeve/sliders. chances are the rubber bushings are gone
Old Oct 24, 2013 | 08:00 AM
MJKH84's Avatar
Thanks Rich
Old Oct 24, 2013 | 12:33 PM
richphotos's Avatar
Not a problem, Good luck, its an easy job, when putting the new bushings in, lube them up
Old Oct 26, 2013 | 02:14 PM
abig84's Avatar
i never knew they actually sold those bushings in the calipers. but yeah they go bad all the time. usually the calipers are so cheap i just buy new ones
bassson
May 24, 2014 03:56 AM
comet12401
Jan 21, 2013 10:23 AM
Bob_55
Mar 29, 2010 11:32 AM
Calgary ZR2
Jan 10, 2008 01:15 AM
redpeppers
Apr 7, 2007 04:55 AM
