re: spare tire bracket and mount
Old Jun 4, 2008 | 10:26 AM
ZR 2's Avatar
ZR 2 is an unknown quantity at this point
Default re: spare tire bracket and mount
Hi there, I have a 2001 ZR-2 Blazer, it seems over the years the rust has built up and was looking to remove both pieces to bring them to an autobody to be re-painted. Now a few months back I decided to loosen the bolts slightlyjust to make sure nothing has seized. My only concern is if I remove the bracket & mount to bring to the autobody to have painted, is there anything inside the body of the Blazer holding these screws/bolts in (ie. nuts & washers) and will I have to take apart the inside interior to re assemble everything back together...any info. will be appreciated...
Thanks
Old Jun 5, 2008 | 11:17 PM
KA3AX's Avatar
KA3AX is an unknown quantity at this point
Default RE: re: spare tire bracket and mount
Yeah there is nuts welded to the body from the inside. No you don't have to take apart your interior, just unscrew the six bolts and carefully take the whole assembly off... that's all there is to it
Be sure to grease the bolts before you put everything back together (never-seize grease works great)
Hope this helps!
dmb70
Apr 3, 2012 10:17 AM
bdubs
Dec 25, 2008 08:52 PM
Bad Ramer Jamer
Sep 16, 2008 10:21 PM
GMdesigner
Oct 4, 2007 01:55 PM
c4gibson
Apr 19, 2006 06:02 PM
