really low oil pressure worried..
Old Feb 19, 2015 | 12:27 AM
blazerhelp01's Avatar
blazerhelp01 is on a distinguished road
Default really low oil pressure worried..
just bought a 2001 chevy blazer had for few days now and noticed the oil gauge was pretty low. about 20-25 when on the gas. when at a stop or just idle is like 5-10. runs good now oil light on seems to have lots of power still and not making any noise in motor. runs quite and smooth.. is this a problem. changed oil and oil filter still the same. oil pressure runs normal first 5 min of cold start up.
Old Feb 19, 2015 | 03:27 AM
newguy's Avatar
cuold just be the gauge. What weight oil you use?
Old Feb 19, 2015 | 12:32 PM
5w-30 with Lucas oil stabilizer
Old Feb 19, 2015 | 12:35 PM
Gonna go thicker next oil change not sure what's the best weight. I live in desert so it gets hot here.
Old Feb 19, 2015 | 02:30 PM
Best to remove the oil pressure sending unit and the check oil pressure with a gauge, (dash gauges are not known for their accuracy).
5w30 is the recommended weight oil. If you use thicker/heavier oil, you're asking for trouble. It will increase oil pressure, BUT, oil volume will decrease, which is far worse than low pressure. Forget the additives and use a full synthetic oil like Mobil1, Castrol, etc. Far better than trying to re-engineer the oil with a band-aid in a bottle.
If oil pressure is not within spec, diagnose the problem & repair it the right way. It might be something as simple as a faulty bypass valve.
4.3vortec
Aug 15, 2014 02:25 PM
chris015
Jul 3, 2011 10:22 AM
Spectreblazer
Mar 15, 2010 11:16 PM
FirehawkNS
Jan 9, 2009 10:38 PM
jman_08
Dec 5, 2008 06:35 AM
