Rear Brakes Groan/Squeak/???
Old Oct 15, 2018 | 01:41 PM
Mike.308's Avatar
Originally Posted by odat
Yes you can. A chunk of 2X4 + or - will prob be enough and prob don't even need to be tied in. The pistons usually don't blow out like a bullet it's just the fact they will come apart and rebuild kits are a real PIA to get anymore
Sure, sure LOL. Once a friend gave me a handy tip, that You may blow the pistons out of the caliper with a compressed air applied to the inlet socket. I was in a rush and skip the part of covering the caliper with a rag. Just made a quick check the piston doesn't blow up into my face. Then, within a same moment I've seen the black oil drips going towards the ceiling and had a thought "oh sh... the bleeding valve is open". OK, I know it's a difference with the compressed air, I just wanted to share an anecdote and the tip
I've been using the BBP rebuild sets over a year ago. I am satisfied with their quality.
Old Oct 15, 2018 | 09:36 PM
odat's Avatar
mike.308
yup been there done that, piston blowout without a rag cover can have the same effect. LOL
Old Oct 20, 2018 | 07:34 AM
LannyL81's Avatar
Well aware of the piston movement. Have not had even a minute to consider doing anything to my Blazer, it has just been sitting. Perhaps Sunday I will find the time to remove the rear calipers and put something between the pads to simulate a rotor.
Old Dec 16, 2018 | 07:41 AM
LannyL81's Avatar
Thought I should update this posting with what the noise source was from; it was the two sheet metal clips that go into the caliper bracket and then then the brake pads go into. They were loose on both sides.
I simply bent them so they were tight in the caliper bracket. Made getting the pads in a bit more difficult but got both sides in and no more noise.
So all good now.....
mkm1387
Jul 30, 2012 11:37 PM
bill737
Jun 24, 2011 04:24 PM
KaNblazerfreak
Feb 7, 2009 07:12 AM
red_dragon
Aug 2, 2008 07:03 PM
nero7997
Nov 16, 2006 02:53 AM
