Rear Defrost
Rear Defrost
My rear defrost is not working. When I push the button the light does not come on any more and neither the rear window or the side mirrors heat up I checked the fuse and put a new one in and nothing it was a 30amp fuse if I was checking the right one any other ideas.
Thank You
Thank You
RE: Rear Defrost
get a DMM and check for power at the switch and at the leads in the back. might be a loose wire or someting.
RE: Rear Defrost
If you fix the defogger, that should also fix the heated mirror problem. It could be loose wiring, a relay or the HVAC control module.
Do you know the a/c RPO, is it C68?
RE: Rear Defrost
Ac RPOs are from C60 - C69
ratrodsare4ever
04-12-2011 08:57 PM
