Rear Diff Question
Old Oct 17, 2011 | 02:20 PM
bigcountry58's Avatar
bigcountry58 is on a distinguished road
Arrow Rear Diff Question
2003 5-speed LS
So I went to replace a caliper this weekend to find that the backing plates and parking brake hardware was totally rotted out.
Long story short I had to pull the axles and all that fun stuff... I fortunately have an 8.625 rear end, but when I got to the parts store to get the rear axle seals I get a question.
Manufactured in US or Canada? Thinking at the time, it was made in Linden NJ so US.
Get back home put everything back together, upon cleaning the diff cover I find a stamp 'Made in Canada' .
So my question WTF is the difference in the seals? I looked at the old seal and it was exactly the same as the new, but for whatever reason the one I have is the same for 7.625 and 8.625 made in US, but the 8.625 made in canada is a different part.
Everything seems to be ok, drove it to work and no leaks and it seemed to fit fine... anyone have any idea? I have looked all over to no avail.
Old Oct 17, 2011 | 02:52 PM
TripleBlackBlazer's Avatar
I think the axle seals would be the same since the diameter of the housing is the same. It's merely the overall length (ZR2) and ring gear size (8.5/8.625) that are different and would require different parts than a 7.625 rear (axles, bearings, gasket, etc.).
Did the parts store have different part numbers for US/Canada 8.625 rears?
Old Oct 17, 2011 | 03:04 PM
8660S
7.625" R.G.; 8.625" R.G.; Axle Code "K"; Mfg. in Can.
SpecificationsShaft Size (A)
1.399
Housing Bore (B)
2.292
Outer Diameter
2.296
Width (C)
0.46
Lip Material (D)
Nitrile
Series
8000
Type Illustration
48
710166
7.625" R.G.; 8.625" R.G.; Axle Code "C"; Mfg. in USA
1.399
Housing Bore (B)
2.29
Outer Diameter
2.294
Width (C)
0.5
Lip Material (D)
Nitrile
Series
710000
Type Illustration
74
710506
Rear Axle; Outer; AAM 8.625" R.G.
2.088
Housing Bore (B)
Outer Diameter
2.777
Width (C)
0.5
Lip Material (D)
Nitrile
Series
710000
Type Illustration
86
Nevermind I found the differences, obviously it has to be between the top 2, and the difference is .002 of an inch... Guess I will just wait and see what happens.
Info from national oil seal website
jkyle187
Mar 1, 2015 06:26 AM
6Cyl'erThriller
Oct 15, 2011 06:11 PM
unclecbass
Jun 28, 2011 05:27 PM
Aquahallic
Aug 7, 2006 05:45 PM
zoni
Jan 16, 2006 04:49 PM
