front and rear diff question
Old Feb 24, 2015 | 04:22 PM
jkyle187's Avatar
jkyle187 is an unknown quantity at this point
Default front and rear diff question
2003 blzr 4x4 4wd
Does my front and rear diffs have drain plugs and fill plugs?
Thank you in advance.Tony.
Old Feb 24, 2015 | 04:57 PM
lazyboyjake's Avatar
lazyboyjake is on a distinguished road
They should both have fill plugs but I'm not sure on the drain plugs
Old Feb 24, 2015 | 08:55 PM
babydeuce's Avatar
babydeuce is on a distinguished road
The front will have a fill and a drain. The rear is a real crap shoot. I have had 4 S10 ZR2's all of different years, only my 2000 has a rear drain plug. You will just have to look.
Old Mar 1, 2015 | 05:30 AM
LannyL81's Avatar
As stated above, the front diff has drain and fill plugs. The rear diff only has a fill plug, drain by removing cover.
The front diff is filled in two ways: get a hose that will wedge into the fill port or just use the vent hose already there, clamped to the radiator shroud.
The rear requires a hose to fill as well. Be sure to get a new gasket for the rear cover. If the rear cover is really rusty, easier to just get a new cover.
Did this job on my '02 last year. Not a bad job....bit messy, but not bad. Do the transfer case at the sametime. Note: transfer case uses a different lube than the diffs.
Old Mar 1, 2015 | 06:26 AM
jkyle187's Avatar
Did the front and trans case yesterday... 13 mm drain and 15 mm fill on front(1.3 Qts)..trans drain and fill was a large allen wrench(1.5 Qts ish)...1 1/2 hr labor after clean up...ill do rear next pay day...
6Cyl'erThriller
Oct 15, 2011 06:11 PM
simmonsnick
Feb 5, 2011 05:50 PM
dougg01
Mar 17, 2010 10:49 AM
Brianator99
Aug 30, 2009 06:18 PM
aaron.b
Aug 11, 2009 12:06 PM
