Rear disc brake conversion
Old Jan 20, 2008 | 12:52 AM
dimmuborgir6nik6's Avatar
dimmuborgir6nik6 is an unknown quantity at this point
Default Rear disc brake conversion
Has anyone done a rear disc brake conversion, and I'm guessing it's pricey, but how pricey?
I recently got new drums but they've been squeaking loader and loader each day. Gonna take them to get checked out but I figured if I'm gonna upgrade, might as well do something that's actually worth it.
I know some of the models were made with 4 disc brakes.
Old Jan 20, 2008 | 03:26 AM
Millertime21's Avatar
Millertime21 is an unknown quantity at this point
Default RE: Rear disc brake conversion
98+ came withdisc brakes. From what I read it easiest to just swap the whole rear axel from a 98+ blazer. Basically you just swap rears and every thing else just bolts up and works. Try car-parts.com and you can find complete axels with brakes for under $200 or atleast in my area you can.
Old Jan 21, 2008 | 03:10 AM
thegr81's Avatar
Yea you can just swap out rear axles, and everything will bolt up to it, then bleed out the system and there you go!!!
Old Jan 21, 2008 | 06:26 AM
You'll want to look at the proportioning valve differences.. Calipers require more fluid than drum cylinders.
Old Jan 21, 2008 | 12:45 PM
94blueknight's Avatar
94blueknight is on a distinguished road
i was just curious (dont know if i'll ever do a drum/disk change but considering it for a future mod) would the rear axle bolt right up to a 94 or would it just be better to convert the brakes themselves?
Old Jan 21, 2008 | 01:58 PM
HeyYou's Avatar
HeyYou is an unknown quantity at this point
It has been stated that these axles are basically that same thing that is under a Camaro/Firebird, wonder if it would be possible to grab the rear disk stuff off of an 89 or newer car, and simply bolt it onto the blazer.... grab the proportioning valve while you are getting the brake stuff?
Old Jan 22, 2008 | 12:33 AM
My friend at work has a Firebird. If I bring a jack one night, I'll do a quick swap. He won't know about it.
Old Jan 22, 2008 | 02:28 AM
thegr81's Avatar
ORIGINAL: dimmuborgir6nik6
I think he would figure it out first stomp of the gas LOL!
Old Jan 31, 2008 | 01:35 AM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
I've been thinking about doing this for a while too, because my drums are really rusty and probably need replacing. I'd rather just replace the entire rear axle assembly along with discs, if I have to do that anyway. The other benefit is that I'll get a newer rear differential. In fact, those of you considering lifting your 4x4s may decide to do this at the same time you lift the rear.
There's a seller on Ebay that specializes in nothing but S-trucks. They basically salvage junked trucks and sell the usable parts. The link is here: s10warehouse.
tri94bbc
Jun 6, 2011 08:00 AM
Mark_D
Apr 29, 2011 11:40 PM
kickme005
Aug 10, 2010 11:37 PM
quinn1991
Tires and Wheels
Dec 28, 2008 02:41 AM
Blazar1996
Tires and Wheels
Sep 10, 2006 04:57 PM
