rear door lock not working
rear door/ hatch lock not working
I have a 2000 2WD Chevy Blazer, 2 door. It does NOT have keyless entry. The window release button works but the window opens only if someone is there to pull it open. I can hear the parts moving and the lock will unlock/lock the front doors (with key) but I cannot open the window if i am alone. I have taken the door panel off and can see the parts but when i turn the key nothing moves. Should there be a visible part?
not really.
the guts in the power window sit BEHIND the inner skin. you can peel off the black skin liner/moisture barrier and reach up on the inside and pull on the channels to see if they are loose.
you can take the whole damn thing appart if you lower the window all the way down and pop it out.
I am sorry I forgot to say it had a drop gate and the window lifts up. I have had the panel off but I did not get all the way into the parts are. Could the actuator be weak and just not putting enough pressure to open the window? Isn't the key is supposed to pop the window open? That is why I asked if there was a visable part--I would think that I would hear or see something move when the key is turned. Has anyone had anything like this happen? Any ideas what to try?
he's talking about the hatch. I noticed the same thing on mine tonight when I was playing with my new two door Blazer. I can't get the rear door open! lol.. I got the hatch glass up, but can't figure out how to get the door open.
vanillathrilla,
i am a she... in my blazer, the handle to open the drop gate is just left of center, there is a handle that lifts up and the gate opens like a tailgate on any other truck.
AB,
I guess I called it a door but it is a hatch.
My problem is that unless there is someone there to pull the window at the same time i push the lift release button (on dash) I cannot get the hatch window open. Once the window is open I am able to open the drop gate but I would like to figure out why the key is not working.
AB,
vanillathrilla,
AB,
AB,
you called it a door once, then went and called it a gate. now you've switched to a hatch.............it's a tail gate, plain & simple.
in regards to the key not "popping" the window, it sounds like the solinoid is gone in your TG (the one for the key function, not the front switch).
I got similar problem with my jimmy button works fine but the key in back or the handle that surrounds key has broken loose I need to know how to replace the lock unit bigest part would be taking off the panel without messing it up.just plain lucky...
rd-blazer
09-19-2011 02:14 PM
rossg
05-27-2009 07:48 AM
