Rear glass release button
Old Jul 10, 2012 | 11:51 AM
mr.vls's Avatar
Thanks for the brief write up. I was wondering what was involved.
Old Jul 10, 2012 | 02:58 PM
rntbuck's Avatar
rntbuck is on a distinguished road
Originally Posted by Pewter2002
On my 2002, it wasn't bad, took ~ 20 minutes. Lower the tailgate, remove the screws, including the ones at both edges of the gate, holding the plastic panel in place. Remove the inside lift handle screws, pop the panel off. Then remove the screws holding the rectangular metal panel in place and remove the panel. You can now see the innards. A clip holds the switch in place, remove it, disconnect the harness and reassemble. Fairly easy job.
perfect...thanks, exactly what i was wanting to know....its forever irritating not having that button work, but for some reason ive never dug into it. as soon as i get my 4wd going again (UGH) ill be looking at a new button back there
Old Jul 11, 2012 | 07:03 AM
slowpoke's Avatar
slowpoke is on a distinguished road
This thread has now answered my original question as to whether these switches are a common problem. The first time I went in there I could see that there really wasn't much protection against water intrusion. GM could have put a rubber boot over the outside of the switch that would have also served as a gasket between the switch and the hole. If I can come up with a way to do that, I'll post it up.
Old Jul 29, 2012 | 03:44 PM
slowpoke's Avatar
Default Update
I got into the switch today, opened it up to diagnose. I had thought to find corroded terminals, but everything was clean and bright. The problem turned out to be the contact spring. Within the body of the switch are two concentric coil springs, the outer one is purely for return pressure on the pushbutton, the inner one makes the electrical contact. This inner spring was just compacted enough that it didn't reach the two contacts about 20% of the time, but my experience with the original switch, which lasted from '03 up to '10 was that the failure rate gradually increased over time to 100%. The remedy is to stretch the inner spring slightly, not too much and not at an angle, so it is a little longer. If the spring is too long, it will make constant contact; of course, you just want momentary contact.
After stretching the spring and reassembling the switch, I tested it thru several dozen cycles with a continuity tester and it didn't miss once. I do have a new switch on the way, and it will be a spare. Of course, we all know that when you have a spare part on the shelf, the installed part will never fail. Think of it as insurance.
BTW, the part number for this beast is 15760719.
blazen_red_4x4
Aug 2, 2020 03:18 PM
Bagherra
Feb 25, 2015 11:55 AM
blazindude
Mar 24, 2012 08:56 PM
chris015
Jul 28, 2011 01:57 PM
kymatt
Aug 27, 2010 08:47 PM
