rear vision mirror
Old Nov 5, 2018 | 03:52 PM
captblackleg's Avatar
captblackleg is on a distinguished road
Default rear vision mirror
My rear vision mirror fell off yesterday, the sticky pad it attaches to has lost its stick with old age. Any ideas on how to stick back on? Super glue?
Old Nov 5, 2018 | 04:03 PM
vadatara2's Avatar
vadatara2 is an unknown quantity at this point
Any parts store sells mirror adhesive.
Old Nov 5, 2018 | 05:22 PM
G0LFADD1CT's Avatar
G0LFADD1CT is an unknown quantity at this point
Yup, but make sure both surfaces are very clean.
Old Nov 5, 2018 | 07:13 PM
And follow the instructions. You only need one drop of glue. This is one case where more is NOT better.
Old Nov 5, 2018 | 07:30 PM
I've stuck them back on with double sided 3M exterior trim tape before :P not a permanent solution by any means, but it would last you a good wile so long as you prep the surfaces good.
Old Nov 5, 2018 | 09:10 PM
odat's Avatar
Something I have found to make it easy to get the mirror in the exact same spot on the windshield is - before cleaning the glass on the inside if there is still glue residue on the windshield go to the outside and draw with a marker around the edge of the residue. After mirror is reattached the marker washes off with window cleaner
Old Nov 6, 2018 | 09:23 PM
AJBert's Avatar
I've never had any of the DIY glues to work worth a dang. The last time I had one fall off I brought it to a windshield replacement place and had them put it on. Cost less than buying the stuff from the auto parts store.
Old Nov 8, 2018 | 02:41 PM
Thanks, guys, lots of good advice. I've found some rear vision glue at a parts store to use.
Asantella
Mar 15, 2019 07:22 PM
Fusefinder
Oct 22, 2010 05:01 PM
oceaneyes823
Jun 28, 2008 08:26 AM
farleyeod
Dec 23, 2007 01:02 AM
felonyblazer96
Nov 7, 2007 11:16 AM
