rear wheel bearing repair kit
Hi
My question is stupid. My friend bought rear wheel bearing repair kit (see photo). My question is how to install it? What is outside side (wheel side) and what is inside side (diff side)? Is it possible to install it olny one side? I need to aske these questions before removing old bearing so maybe my question is stupid and is only one possible way to put it on the axle?
Regards, Marcin
Regards, Marcin
The rubber seal goes to the outside (wheel side).
Thank you
Hi
Now my friend has installed the bearing set. But I am not sure if it is installed correctly, should part of the bearind be visible outside? See photo below (sorry for quality).
Regards, Marcin
Regards, Marcin
What did the old one look like? To me, that does not look right.
Old one looks different but original bearing is not so wide. Repair kit is wider and maybe it should be mounted like this, but I am not sure.
Regards, Marcin
Regards, Marcin
If things were shorter with the original... This may be the "problem solver" type
IIRC, there are two different wheel bearing designs. One with a bearing and a separate seal which is the stock configuration. The other is what is called a "problem solver" bearing which is an assembly with the bearing and seal in one. This moves the seal out further on the axle shaft so it can run on a portion of the axle that was not previously worn down from the seal, etc.
I would have cleaned up the axle in that area a bit more though. And definitely make sure that it is pressed into the axle housing all of the way.
swartlkk is correct....
The rear wheel bearing repair kit is to put the seal and part of the bearing rollers on a different part of the axle.
Sometimes, when a rear wheel bearing is leaking, it is likely caused by a worn bearing. However, the axle is notorious for wear as well. If you just replace the original bearing and seal with an OEM part, since the axle is worn also, the problem will re-surface very quickly especially as far as the leaking seal.
The bearing "repair kit" is a one-piece design that incorporates the seal and bearing together, and moves it slightly to the outside of the original.
What I see in the pics looks correct.
HCII
HCII
It is something you call "problem solver". Thanks for advice.
Regards, Marcin
Regards, Marcin
jeffintoronto
05-18-2013 05:10 AM
ComputerNerdBD
08-30-2011 10:59 PM
ComputerNerdBD
Tires and Wheels
03-05-2011 05:50 PM
