Rear Wheel Bearing Size
Old Dec 29, 2017 | 04:08 PM
jaatecart's Avatar
jaatecart is on a distinguished road
Default Rear Wheel Bearing Size
For the sake of clarity, does anyone know the correct rear wheel bearing diameter for an 01 Blazer 4wd (GU6)? Based on what my local parts store lists on their website, it seems that they may have this and the 8" ring gear bearings confused. Thanks!
Last edited by jaatecart; Dec 29, 2017 at 04:22 PM. Reason: Simplified question, found solution to part of previous post
Old Dec 30, 2017 | 08:01 AM
oldeerslayer's Avatar
oldeerslayer is an unknown quantity at this point
On my 98 (same as 01) Blazer rear axle I used Timken 5707 It specs as 1.4016 (or 1.402) x 2.252 x .698. To get the old ones out I used a 4' piece of conduit right through the differential and a 2 lb hammer. You can buy or rent a puller with outside hooks made for pulling them. Conduit was on hand and the right price. The new ones go in pretty easy using a piece of 2" copper pipe and hammer. The copper won't damage the bearing since it rests on the outer race. A round block of hardwood would also work if it's 2-1/8 to 2-1/4 dia. They aren't an interference fit so they go in pretty easy. There is also a bunch of stuff regarding whether it is a Buffalo or Canadian axle for which seal to use. Either will work. The axle on my truck had one of each when I took it apart and neither was leaking. But since i was in there already I put in new ones. Rather than have to drain the diff in the future.
brianp
Jun 1, 2020 10:30 AM
jimspahr@msn.com
Dec 29, 2015 04:57 AM
ComputerNerdBD
Aug 30, 2011 10:59 PM
ComputerNerdBD
Tires and Wheels
Mar 5, 2011 05:50 PM
skoot
Jan 23, 2007 05:17 AM
