rear windshield wiper washer fluid
i have a 95 blazer and in it there is a switch to turn on the rear winshield wiper and then if u hold it down the rear windshield wiper fluid should come out to clean the window. the fluid is not coming out and i have no idea where it is supposed to be coming out from. i filled my washer fluid to the top and still it doesnt work. does anyone know what the problem is? thanks
It is possible that the pump for the rear wiper has failed. The pump is located in the washer fluid bottle alittle higher than the pump for the front wipers. You should hear a pump up front turn on when the button is pushed. Have someone in the truck with the key just in the 'ON' position turn on the rear wipers and hit the button. If you hear the pump, then you either have a restriction in the line or a disconnected line somewhere between the pump and the rear wiper. If you don't hear the pump, then either the pump is shot or you aren't getting power to the pump either due to a broken wire or a faulty switch.
I liked it better when there was a front and rear container. Less hose to replace if it goes bad. Not to mention how its routed.
joshua_andrew92
03-18-2010 03:01 PM
Matty Kling
10-10-2007 01:25 PM
kaindragoon36
03-25-2006 04:22 PM
fruccoman
02-15-2006 07:08 PM
