Rear wiper doesn't work - need help
Where can I get the wiper cut out switch? I pulled that out and 1 terminal is really corroded, the others are getting there. Can it just be pulled apart and cleaned?
Your best bet would likely be the dealer. I'd try cleaning it before replacing. What harm could you do? At the very least, you could just jumper the connection for the time being, knowing that you will have to turn the wiper off if you want to open it up with the vehicle running or have it open with the vehicle running.
I'm finally getting back to this. It seems the dome lights do stay on. How do I bypass the cut out switch? Which wires can I jump? I can take any pics you may need.
Thanks in advance.
Thanks in advance.
Disconnect the rear window ajar switch and jumper the wires together. Schematic attached:
Stoober
10-15-2014 03:21 PM
lazer2000
09-16-2012 11:16 PM
99blzr
12-18-2011 06:47 PM
lionel2
03-24-2011 08:29 AM
Blahman20
06-18-2007 09:20 PM
