Remote Keyless Module Troubles?
I've had this happen a couple times now. The last time was a month or two ago with no more issues til now. Tonight I went out to the Blazer to head home. Using the remote to unlock the door worked as usual. When I hit the key everything went dark.The RKE module(under the dash driver's side) was ticking rhythmically. I disconnected the 'Lock' wiring connector and reconnected it. The lights and everything worked fine, it started right up,ran and drove like normal.
Is this common symptoms for a module gone bad or something else. Was disconnecting and reconnecting just a coincidence that it then worked?
Any help would be great. I'd hate to have this happen when my wife has the rig and I'm not there. It's a 95 4door, push button 4X4 S10 Blazer
Tom
Tom
Well I see you've been around for over a year now, so I'm not sure why you'd be posting in this board.
Please take the time to read board descriptions and post in the appropriate board. This particular board is for new member introductions only, not tech related questions/problems. I'll have the thread moved for you, but in the future please be sure to post in the right board!
ComputerNerdBD
10-16-2011 06:10 PM
kennyrandolph
02-24-2010 10:45 PM
MOTORSPORTS 1
12-15-2008 02:38 PM
