Remove steering wheel or not?
Old Dec 17, 2010 | 05:47 PM
gmbwrenchn's Avatar
gmbwrenchn is an unknown quantity at this point
Default Remove steering wheel or not?
Getting ready to replace the ignition switch. Found a few proceedures on doing this. Question I have is some say remove steering wheel, some don't mention removing it at all. Could someone please clear this up for me? Is it necessary or not, Thanks.
Old Dec 17, 2010 | 06:12 PM
The sound insulator and knee bolster along with both of the column covers need to be removed. Removing the steering wheel makes it a little easier to see what you're doing, but it's not necessary. If you do remove it, be very careful of the clock spring, it is expensive. When the wheel is removed, DO NOT turn the steering shaft.
Old Dec 17, 2010 | 06:47 PM
gmbwrenchn's Avatar
Where is or please discribe the the sound insulator and knee bolster.
Old Dec 17, 2010 | 06:50 PM
Sound insulator is black plastic panel above brake pedal, (has the OBDII connector attached to it). Knee bolster is the panel just below the steering column.
Old Dec 17, 2010 | 06:58 PM
gmbwrenchn's Avatar
Ok thanks. Have you ever had to replace the ignition switch in a 97? If so, any tips would be appreciated, Thanks.
Old Dec 17, 2010 | 07:18 PM
There's "How-to" thread here some place, but I can't find it, maybe someone else knows where it is.
litterbug
Oct 19, 2011 07:50 AM
caseroj
Oct 20, 2010 08:10 AM
Cavalier z24
Sep 3, 2009 08:20 PM
fou99
Dec 24, 2008 12:35 PM
Smoked
Jul 25, 2008 07:31 PM
