Removed steering shaft and can't get it back on
Old Dec 19, 2013 | 06:05 PM
jimmac23's Avatar
jimmac23 is an unknown quantity at this point
Question Removed steering shaft and can't get it back on
PLEASE HELP! I removed the steering shaft to get to the #3 plug on my 96 Blazer. It didn't slide off easily, I used a very large screwdriver to slide/pry it off. It was so tight coming off that I'm wondering if the problem is that i cannot get enough leverage to muscle it back on. I put an alignment mark on before I took it off and that seems fine. Should I try to hammer it on with a block of wood? Anyone else had this problem?
Thanks.
Jim
Old Dec 19, 2013 | 06:16 PM
scottl1346's Avatar
scottl1346 is on a distinguished road
it is keyed so it will only go on one way. i had the same issue had to use a hammer to get it to slide back on use some wd-40 or something to help you
Old Dec 19, 2013 | 07:12 PM
jimmac23's Avatar
Thumbs up
Thanks, I was able to get my 18 inch pipe/breaker bar on it and hammered it home. Appreciate the help!
Mcg89
Mar 7, 2014 07:35 PM
importsky22
Aug 27, 2012 07:14 AM
vital velocity
Aug 1, 2011 11:42 AM
blacer2000
Sep 5, 2010 09:01 AM
bigdaddykane93
Aug 26, 2009 01:07 PM
