removing the fuel filter on a 99 Blazer
Old Aug 31, 2008 | 11:12 AM
Blazer1999's Avatar
Blazer1999 is an unknown quantity at this point
Default removing the fuel filter on a 99 Blazer
I want to change the fuel filter on my 99 2WD Blazer. I have located it on the inside of the drivers side frame rail. My question is do I need a special tool to remove the front fuel line hookup into the fuel filter. I see how the rear connection seperates but am not sure about the front. Thanks for any help on this topic,Bob
Old Aug 31, 2008 | 11:22 AM
dBsound's Avatar
dBsound is an unknown quantity at this point
Default RE: removing the fuel filter on a 99 Blazer
Those nuts can be a b***h to get loose! I ended up taking mine to TWO mechanics. The first one got so frustrated with it, that he gave up, and told me to go elsewhere.
BTW- I think you need a line wrench to do it.
Old Aug 31, 2008 | 11:31 AM
riceh8r0512's Avatar
riceh8r0512 is an unknown quantity at this point
The proper wrench to use is a Flare Nut wrench. I bought a set when I went to change my fuel filter, but the thing was rusted on so bad I ended up taking it to my mechanic. He got frustrated and just cut the line and repaired it.
Old Aug 31, 2008 | 11:41 AM
dBsound's Avatar
^^Haha! So it wasn't just my guy. He worked on it for about 30 minutes(on a sweltering day), then came to me, cussing like a sailor, "Dave, get this %^&*ing thing outta here!"
Old Aug 31, 2008 | 01:54 PM
The trick is in soaking the threaded connection for a week or two before attempting to disconnect it. After soaking it, it should not be all that difficult to break loose. And definitely invest in a set of line wrenches prior to tackling this project. Just use a set of regular open wrenches first to get the proper sizes. Both are odd sizes if I remember correctly.
The other side is a quick connect fitting. You can pop this loose with a small screw driver and a bit of time. The "windows" in the black plastic part are where the white plastic clips go. To release the connection, push in both of the white plastic clips at the same time and pull back slightly on the line. It will come loose.
Old Aug 31, 2008 | 02:19 PM
Canadian88's Avatar
Canadian88 is an unknown quantity at this point
They are odd sized, I used vise grips on one nut and an adjustable wrench on the other and after some penetrating fluid, it did indeed come loose. I've done this twice and both times I soaked my chest in gasoline and cussed about the rustedthreads. The quick connect side is a treat compared to the wrenching side.
Old Sep 3, 2008 | 10:26 AM
97ssblazer's Avatar
97ssblazer is an unknown quantity at this point
i had to take mine to a shop they kept it over night to soak the threads...
aerovette99
46
Sep 28, 2015 10:04 AM
95jblaze
Aug 27, 2011 03:46 PM
brianroark
Jun 25, 2010 03:14 PM
riverjamie
Sep 24, 2007 08:21 PM
guywm25
Mar 26, 2007 12:31 PM
