replace powered door with manual door
Old Mar 6, 2012 | 05:05 PM
firstblazer's Avatar
firstblazer is on a distinguished road
Default replace powered door with manual door
So I have an 01 4-door blazer. Its blue with a red door. I have all power but the colors do not match. So I found a blue door from a 98 blazer that matches, but it isn't equipped with power options. I should be able to do any work involved but wanted to make sure that it is even possible and that everything will match. Can anyone give me a definite yes that the switch will go smoothly?
Old Mar 6, 2012 | 06:12 PM
pettyfog's Avatar
but wanted to make sure that it is even possible }{ and that everything will match.
heh. You should consider a career in politics.
But on to the solution. You're going to have to pull the door panel, I assume on yours
If there is a hole where the window crank can go, then its probable that the inner door is the same on both
bob_elder
Jan 8, 2010 08:17 PM
andrewjs18
Dec 30, 2007 01:27 PM
sasquatchfound
Aug 8, 2007 06:21 PM
paulf707
May 21, 2007 07:05 AM
DavidBoone
Jun 8, 2006 06:46 PM
