Replace Turn Signal Switch
Old Sep 7, 2011 | 11:40 AM
hace1's Avatar
hace1 is on a distinguished road
Default Replace Turn Signal Switch
How hard is it to replace Turn Signal Switch, it is sufficient to remove the lower and upper protection of the steering column?
Old Sep 7, 2011 | 12:42 PM
Check out the Tech Article (DIY) Index (link found in my signature below).
Old Sep 7, 2011 | 01:46 PM
hace1's Avatar
Thanks, that i think i can manage!
Old Sep 25, 2011 | 05:29 PM
mjt's Avatar
mjt
mjt is on a distinguished road
Anyone know how to remove the tilt wheel lever which goes thru the lower cover?
Old Sep 26, 2011 | 12:40 PM
hace1's Avatar
Just pull straight out.
Old Sep 27, 2011 | 11:07 AM
mjt's Avatar
mjt
Anyone have a reliable source for that turn signal/multifunction switch?
Old Jun 11, 2012 | 08:55 PM
9t8z28's Avatar
9t8z28 is on a distinguished road
Yes, I am bringin this back from the dead! SWARTLKK, your DIY LINK contains no INFO about replacing the turn signal switch. Am I missing something here?
If I am, please point me to it or if the info doesnt exist, can someone tell me how to replace the turn signal switch on a 95 Blazer?
Old Jun 11, 2012 | 08:59 PM
Originally Posted by 9t8z28
Yes, I am bringin this back from the dead! SWARTLKK, your DIY LINK contains no INFO about replacing the turn signal relay. Am I missing something here?
If I am, please point me to it or if the info doesnt exist, can someone tell me how to replace the turn signal relay on a 95 Blazer?
Considering that this thread is discussing the turn signal switch (a.k.a. multifunction switch) and not the relay, I wouldn't expect it to say anything about the relay or flasher... I would say you missed the entire topic of this thread...
Also considering that the OP drives a '98 Blazer, my reply was perfectly to the point as that topic is covered in the Tech Article (DIY) section - scroll down to the Electrical & Lighting section of the index linked to in my signature & it's the 5th or 6th link. If you drive something different, than this thread likely isn't for you and you should probably post your own thread...
Now since you asked so politely, to replace the turn signal flasher (a '95 does not have a turn signal relay), you simply pull the flasher out of its socket and insert the replacement.
SubbinBlazer
May 24, 2013 12:56 PM
88Chevy
Jun 21, 2012 11:53 AM
crazy cora
Oct 25, 2010 09:45 PM
ta3ff
Oct 14, 2009 05:07 PM
shaka1111
Feb 13, 2006 02:23 PM
