replaced caliper bracket
Old Mar 22, 2009 | 04:09 PM
blazzer99's Avatar
blazzer99 is on a distinguished road
Question replaced caliper bracket
hi everybody my name is george and i have a problem with my blazer 2 doors, 4wd, 4.3ltrs, 1999, was making a noise and i decided to check, well the pads are to old, i replaced them with a new ones, but the pedal is to soft! spoongie) i try to purge or bleed the fluid but i can not turn the bleed screew, beside, the rear caliper it seem to be old and the bracket is no moving, can some body help me! please,
Old Mar 22, 2009 | 05:45 PM
*Moving to 2nd Gen Tech*
Just replacing your pads should not have caused the pedal to be spongy... Something else must have happened. As far as bleeding the brakes, you are going to have to get the bleeder open. If you damage the bleeder, you can get new ones from the parts store. You just have to make sure that you get the old bleeder out. If they are being a pain, put some penetrating oil on them and allow some time for it to set in.
I did a run through of the replacement on the rear axle of my old 2000 Bravada. The brakes will be the same in the back. Have a look at THIS THREAD.
Johnr2604
Oct 14, 2013 07:54 PM
lombard
Mar 28, 2011 06:23 PM
mojoman13
Nov 15, 2007 07:42 PM
Swain
Aug 27, 2007 05:01 PM
WisdomRacing
Jul 18, 2007 04:18 AM
