Replaced fuel regulator now no start
Old Sep 12, 2015 | 08:52 PM
Impact's Avatar
Impact is on a distinguished road
Default Replaced fuel regulator now no start
I was having hard starting problem and found the fuel pressure regulator leaking. After replacing the regulator the car wont start, it just turns over but will not start up. Does anyone have any ideas? I can hear the pump running in the tank but no start. I have a 99 blazer 4.3. Thanks for the help
Old Sep 12, 2015 | 09:46 PM
Impact's Avatar
I went to the bleeder port in the eng compartment and all I am getting is air. Is there any other way to bleed the lines. I think this might be the problem
Old Sep 12, 2015 | 10:11 PM
akaSPITTYBAYS's Avatar
akaSPITTYBAYS is on a distinguished road
should be no reason to have to bleed the line if the pump is working properly
check all the lines back to the tank if there no breaks crack the output connection on the top of the top of the tank. If on the three second prime no fuel is spitting back there you have a dead pump
is your truck on an angle these baby's are classic for zero fuel in the nose down position
Old Sep 12, 2015 | 10:53 PM
Impact's Avatar
My mistake, looks like I didn't prime the sysyem long enough. I do have fuel pressure at the port but still no start. I don't smell any fuel so I am guessing it is a fuel problem. I guess it could be a bad regulator
Old Sep 13, 2015 | 11:54 AM
Impact's Avatar
One question, doe the nipple with the o-ring at the end plug into anything? When I look inside the spyder all I see is a open cavity. Is is just there to hold the screen on?
Old Sep 14, 2015 | 10:09 AM
Blazer_4x4's Avatar
Blazer_4x4 is on a distinguished road
The nipple on the regulator does Not connect to anything, do not plug it off. It uses the manifold vacuum while sealed inside of the upper manifold.
Old Sep 15, 2015 | 07:41 AM
Impact's Avatar
The fuel tube down the center of the spyder manifold came out, I found it on top of the transmission. Thanks for the help. It all doesn't matter now, seems like one of the fuel line nuts went into the manifold and now I have a blown engine. Guess I should have covered the openings more carefully. RIP
north40s
Oct 19, 2011 05:00 PM
wallace
Feb 15, 2011 09:45 AM
yanni011
Jan 7, 2011 08:59 PM
95Jimmy
Oct 4, 2009 07:21 PM
broke33
May 1, 2007 10:45 PM
